Sonicstage Question
Discussion in 'Headphones, Earphones & Portable Music' started by newbie265, Jun 1, 2005.
  1. newbie265
    newbie265
    May 21, 2003
    467
    Rochester, Kent
    +5
    I couldn't understand why people were moaning about this software but I am having a few difficulties now.
    I changed The band initial on sonicstage (eg The Beatles to 'B') but has transferred to the HD5 as 'T'. Also grouping a cluster of songs in one album name but are transferred to individual album names on the HD5 as well as changing the order I put them in.
    Hope this makes sense.
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,436
    +6,222
    Hmmmm, changing intials was OK for my HD3. At least your HD5's buttons haven't cracked! :)
  3. newbie265
    newbie265
    May 21, 2003
    467
    Rochester, Kent
    +5
    Sorted the ordering out the double albums I have grouped bothe have two track 1,2 etc still don't understand why they can't download as they are laid out in 'My Library' though :confused:
  4. scottydog
    scottydog
    Mar 22, 2005
    55
    I had this problem too. To get around it I had to highlight all of the tracks in the 'album' then right click over them and select properties. Changing the name of the album there will convert the whole album. You still need to do it in 'properties' for the album itself and also the alphabtical letter that you wanted it listed under.
    You will need to delete the album from the HD3 and re-transfer for any changes to take effect.
    For some reason I ended up with two versions of changed lbums in SS3.1. One in the right place and one in 'others'. Deleting the 1 in others worked fine.
    Hope that helps.
  5. djskum
    djskum
    GOD Sonicstage 3.1 is soooo ****y!!!
    Its annoying not being able to change the properties on the files within my HD5! Got a rogue track in the wrong album. Imported it from home (now at work) using 2 copies of sonicstage (at home and work). Can't export as I put this track on at home! Anyway exporting and reimporting is a pain anyway...
    Sonicstage 3.1 = crap software, GG Sony. Try employing some real software developers...
    An angry coffee fuel Deej.
  6. Hrochnick
    Hrochnick
    Apr 28, 2005
    369
    Brno
    +9
    As I remember you can change proporties of the files on your HD5 from SonicStage, you just have to do each file one by one and it's a long and boring process. Quicker by far to delete and reimport if changing multiple files.
  7. sunflowerhx
    sunflowerhx
    Just started using SS3.1 with my HD5; and I initially had afew problems with my tags.
    I suggest you use itunes to convert all your tags to IDE2 v2.3.
    Just load up all your mp3 into itunes, select all and right click -> Convert Tags.
    SS3.1 does not seem to be compatible with the latest IDE2 v2.4.
    Alternatively you could use the excellent Tag&Rename but itunes is free!
    BTW does anyone use Atrac3?
    Tempted to rip some cds using this to save space but I cant find any software apart from SS3.1 to play them on the PC. I cannot find any plugins for Media Player 10 or Winamp etc..
  8. tottycs
    tottycs
    "Sonicstage 3.1 = crap software, GG Sony. Try employing some real software developers..."
    i know it sucks, you shoud try downloading "VAIO music transfer" THAT ROCKS! :D
  9. loser
    loser
    Jun 3, 2005
    36
    can this VAIO music thig be used with HD5?
  10. Simebaby
    Simebaby
    Sep 17, 2004
    736
    Yes. (You need to have SS 3.1 installed).
