philthunder
After my NW HD5 went back I found the prospect of upgrading my car head unit to one of the new Sony ones that play ATRAC3+ cd's. With in the order of 350 tracks on a cd it makes a multi changer a bit of a luxury. So I loaded up a disk on SonicStage and burnt away, but I could not find a way of playing it with SonicStage. Can anyone point me in the right direction. It plays ok on the car head unit and I was amazed at the quality, so that part is a success. Surly if you can compile a disk on SonicSrage you should be able to play it?
