Sonicstage-NW-HD3 Playlists Problem
Discussion in 'Headphones, Earphones & Portable Music' started by *baggie*, Jul 14, 2005.
  1. *baggie*
    *baggie*
    Apr 13, 2005
    23
    I am surprised this issue has not been raised before. The playlist function on Sonicstage seems to work OK. However on the player itself the story is different. If you have playlists the only view that makes any sense is the Goup view but have you ever tried to find an album in a none alphabetical list? In artist and album views the playlist tracks show as duplicate tracks on the original album making these views useless since all the albums containing favourite tracks have duplicated tracks. I use the artist and album views all the time since the lists are in alphabetical order. I have given up using playlists for this reason and lost what is potentially one of the most useful features of the NW-HD3. The problem may also be on the NW-HD5.
  2. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    This issue has been raised, many times before.
    THE HD1/3 DO NOT SUPPORT PLAYLISTS. THE HD5 DOES.
  3. *baggie*
    *baggie*
    Apr 13, 2005
    23
    You can create a playlist in SS 3.1 and transfer it to the NW-HD3. And you can view it in Group mode OK. What you really mean is that it doesnt work properly in album and artist views.
  4. scottydog
    scottydog
    Mar 22, 2005
    55
    Yes thats right. A playlist only appears in Groups. You can drag the list into an alphabetical order or any order you choose if you connect your HD3 to the PC and drag from the list of things on the player. You have to do it every time you import something though or it gets very messy
