sonicstage help pleeeeeeeeease??
Discussion in 'Headphones, Earphones & Portable Music' started by ohms, May 23, 2005.
  1. ohms
    ohms
    Apr 27, 2005
    89
    11
    hey there, i have an old sonicstage version 1.5 on my pc..and i went to install the new version..and when it tries to uninstall the old one an error message comes up with..'the setting of installer is not enough. setup is aborted'
    so now i cant get a new one or do anything! iv searched all over the net endlessly and found no help...can somebody help me please??!?
    thanks,
    Omar.
  2. ohms
    ohms
    Apr 27, 2005
    89
    11
    so can nobody help at all no? occchh.
  3. img
    Jan 22, 2004
    586
    +16
    theres usually an error code with winodws installer problems like that maybe you can have a look.
    or you could try getting msi clean up and deleting the installer info for it and manual remove the files
  4. watchinthewheel
    watchinthewheel
    try uninstalling 1.5 and then installing 3.1 that should work.
  5. wilto
    wilto
    Apr 23, 2005
    309
    Cardiff
    yeah you try and uninstall it as oppose to letting the new sonicstage uninstall it.
  6. ohms
    ohms
    Apr 27, 2005
    89
    11
    i tried that and the same error message appeared..nothing seems to be working!
  7. dzysheep
    dzysheep
    May 24, 2005
    29
    just do a reformat
  8. blzbob
    blzbob
    Oct 6, 2002
    43
    Newbury
    Had this problem myself.
    After 4 weekends of trying to fix the problem and many attempts to contact sony (who asked lots of questions and then ignored me when I answered them) sent it back and got an ipod shuffle. The really annoying thing is I have 2 Sony ATRAC discmen that I can now no longer record onto!
    Hope below may help (helped some but not me) :(
    http://www.hitsquad.com/smm/wwwboard/messages/156021.html
    http://rcd.typepad.com/rcd/2004/09/sonicstage_horr.html
    I do hope the authors of sonicstage die horribly because the devices are great. I used to like sony but if I were slightly more psychotic and a little less busy I would be hunting their board down.
