Sonicstage Atrac conversion info
Discussion in 'Headphones, Earphones & Portable Music' started by Nixit, Aug 28, 2005.
  1. Nixit
    Nixit
    Say if I tell Sonicstage to put atrac files on my mp3 player, will that mean that it changes the source mp3s or will it just convert them for on the player? If it does change the source files, can I just save them in a seperate folder and keep my mp3s?
  2. sulk
    sulk
    Aug 27, 2005
    42
    Sonic Stage creates a seperate library of all the converted files, and thats seperate from your original mp3s, so it doesnt affect them in any way. So your original mp3s should be fine, and it will only convert them to atrac when you send them over to mp3 player, and it keeps the converted file in another folder, again leaving the original alone.
    So basically it leaves the mp3 alone, and puts the converted atrac file in a seperate folder.
    -Sulk
