SonicStage advice
Discussion in 'Headphones, Earphones & Portable Music' started by daveb975, Jul 4, 2005.
  1. daveb975
    daveb975
    Oct 25, 2002
    3,992
    103
    London
    +275
    I am struggling a bit with artist/track naming from SS 3.1 onto my HD5.
    For example, I have two System of a Down albums on there. On SS 3.1 on my PC they appear as the same artist, but on the HD5 itself I have 2 artists:
    System of a Down
    System Of A Down
    Will I need to delete and re-rip the CDs to get rid of this?
  2. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    Delete the tracks from the HD5 and retransfer them.
  3. Fencer02
    Fencer02
    Its case sensitive, the slightest difference and it thinks its a different album/artist.......Edit the differences out and drag and drop it into the same album/artist whatever.........Chronic Stage strikes again ....What a crock of Faeces.
  4. JB5
    JB5
    Apr 18, 2005
    231
    +16
    To avoid this happening in the future, you could always use the drop down menus that contain all the artists and genres currently in your database. So you need only type in new artist or genre info, any duplicates can be simply selected from the lists. (These drop down menus appear on the music transfer screen.)
    I've never used the on-line database option to automatically fill in my track info but after using it you could still check/correct the artist and genre entries before transferring to your HD5.
