sonicstage 3.4 cant transfer some files!!
Discussion in 'Headphones, Earphones & Portable Music' started by NetCini, Mar 8, 2006.
  1. NetCini
    NetCini
    hi all!
    i have a nw-hd3 and using ss 3.3 to transfer my all kind of music with happy(old happy days:))
    but today i installed ss 3.4 and tried to transfer an mp3 file(downloaded-not ripped) but it said
    An error occured while transferring.
    Transfers are not allowed.
    <FileName>
    tried it million times! but no! than tried to rip a cd-it did with atract formats and transfered it. but when i tried to rip the files as mp3, and trying to convert+transfer it says same thing like above.
    theres no problem with tracks on cd.. but i wanna convert my downloaded mp3 files to atract and transfer them.. SS dont let this..
    somebody can help me :lease:
    NetCini
  2. NetCini
    NetCini
    nobody can help?
  3. SilentLucidity
    SilentLucidity
    Sep 17, 2005
    33
    Facing same issue. Once it happened and then I managed to transfer same tracks later. Today it is happening again without any luck.
  4. NetCini
    NetCini
    solved it by formatting hdd.. theres no problem now.. i thought that will be occured by re-install of atrac codec.. my friend installed a foreign dll.. it would broke down the original..
    anyway, i recommend same method but back-up your files before..
  5. SilentLucidity
    SilentLucidity
    Sep 17, 2005
    33
    Found a slightly simpler solution. Delete temp files from Options/advanced/Delete.... and it starts working again atleast it is working for me..
