SonicStage 3.1 hangs / closes when converting to ATRAC
Discussion in 'Headphones, Earphones & Portable Music' started by MikeyUK, Jul 19, 2005.
  1. MikeyUK
    MikeyUK
    I am using SonicStage 3.1 to convert my MP3s to ATRAC Plus before transferring to my Sony NW-HD5
    However, SonicStage only converts about 20 - 30 MP3s successfully before it either closes itself and returns to the desktop, or hangs the system, requiring a reboot
    I know there are loads of issues with SonicStage 3.1, but is this a known problem? If so does anyone have a workaround?
    Cheers, Mike
  2. Mike_manchester
    Mike_manchester
    From my own experience, SS 3.1 (and indeed earlier versions too) is a memory hog - 58mb of Ram for the main program process on my machine at the moment and thats with the program idle !!!.
    How much RAM is installed and how much virtual memory do you have allocated ? - is there enough free space on your hard drive for a decent amount of virtual memory?
  3. MikeyUK
    MikeyUK
    Thanks for your reply. I have 512MB RAM, and 768MB of System Managed Virtual Memory (Win XP)
