SonicStage 3.1 database
Discussion in 'Headphones, Earphones & Portable Music' started by *baggie*, Jun 16, 2005.
  1. *baggie*
    *baggie*
    Apr 13, 2005
    23
    Does anyone have any idea how the default location for the SS 3.1 database can be changed? I have changed the ' Files Imported To ' parameter, and edited a likely registry value, both with no effect. Thanks.
  2. bobjl
    bobjl
    Jun 14, 2005
    13
    3
    Go to Tools\Options\Location to save imported files
    Browse to a new folder
  3. *baggie*
    *baggie*
    Apr 13, 2005
    23
    I have tried this but SS still points to the original database
  4. clivem2
    clivem2
    I've changed mine, it keeps track of files in the old and new locations, it must have an index that points to the file locations. When I changed location and then imported, it worked fine.
  5. KeanosMagicHat
    KeanosMagicHat
    Feb 7, 2005
    4,551
    England, UK.
    +554
    Hmmmm .... if you set up the location of your library as an external drive, would that allow it to be portable to different computers - home / office etc?
    Anyone tried this?
  6. *baggie*
    *baggie*
    Apr 13, 2005
    23
    Does this mean that SS keeps tabs of files in two locations as if it was one database?
  7. clivem2
    clivem2
    Seems to be the case. One location is my C: drive the other is on my D: drive. The file locations must be fully stored (ie including the drive and directory) in an index in the SS installation area.
  8. *baggie*
    *baggie*
    Apr 13, 2005
    23
    By the SS installation area do you mean Tools\Options\Location to save imported files?
  9. clivem2
    clivem2
