SonicStage 3.1 and MP3s probs
Discussion in 'Headphones, Earphones & Portable Music' started by karm990, Jul 14, 2005.
  1. karm990
    karm990
    I have no probs transfering directly from CDs to SS and then into the NW-HD5 player but S.S seems picky about what MP3s on my pc it wants to transfer. Some work fine, others it refuses to do.
    Regardless of size etc of the file it will get to a certain percentage and then it virtually freezes my pc up.
    Only way round this so far is to open the file in an audio editor and then resave, and then it will transfer the "new" file ok - but this is very longwinded way around it!!!!
    Must be others experiencing this???
  2. jack190
    jack190
    The only files Sonicstage 3.1 refused to transfer i had to delete the ID3 tag and reaply the tag for it to work.
    Only happened on 3 mp3's though.
    Not sure if this is the samething though, as it wouldnt even try to trasfer these files of mine.
  3. karm990
    karm990
    Not familiar with ID3 tags???
    How do delete / reapply??
    Thx
