Sonicstage 3.0 anyone using it
Discussion in 'Headphones, Earphones & Portable Music' started by degringo, Mar 4, 2005.
  1. degringo
    degringo
  2. combustion
    combustion
  3. Bennem
    Bennem
    Nov 22, 2004
    23
    3
    I installed it this afternoon and am using right now.
    If you are using the Vaio drag and drop software to get you MP3's onto the NWHD3 then don't install sonicstage 3.0 as it stops this get around.
    I installed 3.0 because I found 2.3 unstable. 3.0 can scan and import large MP3 folders without hanging the machine which is better than 2.3. Although I do need to say that you do need to wait for a while for 2.3 to finish before deciding that the machine has hung. Even if you look at task manager and it says it is not responding it is thinking and will finish.
    3.0 has some useful new features such as the obvious not importing files you already have in your library.
  4. mushroom
    mushroom
    converting is faster than 2.3, but i had to re-inzialized my hd1 after i install SS3.0.
  5. SeanR
    SeanR
    I installed sonicstage 3 and I love it.
    Version 2.3 used to crash after every CD on my computer.
    Version 3 hasn't crashed yet - Thats all I can tell you!
  6. watchinthewheel
    watchinthewheel
    3.0? i thought it was 3.1. either way im using it and its far far better than 2.3 which i upgraded from, its far less crash-prone
  7. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,639
    +6,617
    there was a 3.0, but the 3.1 came along which added HD5 support if my memory serves me right
