sonicstage 2.3 and 3.0
Discussion in 'Headphones, Earphones & Portable Music' started by scratchyjase, Apr 2, 2005.
  1. scratchyjase
    scratchyjase
    Mar 27, 2005
    603
    +9
    whats the difference between the 2
    is it a free download
  2. Spacecowboy
    Spacecowboy
    3 makes it easier to rename, tag multiple files and is maybe a little faster. I actually prefer 2.3, it makes it easier when importing files to SS, u can import directly intop an existing album, rather than import and then move to the album you want manually.
    Plus u cant get tracks off Connect (basically Sony iTunes) with 3 cause its only for US at the moment, but is soon to be released for europe.
    There are prob more differences that others can comment on, but that i cant remember.
    And yes its a free download.
  3. scratchyjase
    scratchyjase
    Mar 27, 2005
    603
    +9
    cheers mate
  4. Roger Matthews
    Roger Matthews
    Nov 11, 2004
    291
    Aberystwyth
    +15
    I would disagree, SS3 is so much better than SS2.3!
