sonicestage question
Discussion in 'Headphones, Earphones & Portable Music' started by jimton, Jun 30, 2005.
  1. jimton
    jimton
    Jun 15, 2005
    49
    Is it poss to transfer some mp3 files back from the mp3 player to your comp? I would of thought you could but, ive deleted them from my libary and its not letting me do it?! :(
  2. T88
    T88
    Jun 11, 2005
    11
    London
    yeh it is possible because the sony is just a harddrive really.....so yeh, u can transfer back to ur comp
  3. Stuart P
    Stuart P
    Apr 16, 2005
    2,115
    +172
    i asked the same question earlier but was told it is not possible. has anyone actually done it & what are the requirements?
    thanks
  4. jimton
    jimton
    Jun 15, 2005
    49
    T88, can you tell how you do this please?
  5. jimton
    jimton
    Jun 15, 2005
    49
    anyone? :lease:
  6. sohc
    sohc
    no as far as i know its not possible... well hmm, i guess if you have sonicstage installed ir wouldnt be a prob. if you open the hd5 as a storage device, you will clearly see that the files are stored in some sort of proprietary format.
    what you CAN do (which ive done) is take the hd5 (or hd3 i guess) to a friends house, and transfer all the music you want onto the player (without any drivers disk). then- you have to plug it into your comp, tranfer all the songs from the hd5 to your comp...import them into sonicstage, then send em back to the player. pain in the ass huh? fortunately usb2 speed makes this a little less painfull.
  7. jimton
    jimton
    Jun 15, 2005
    49
    ive got the hd3, i dont think yo can do it which is a pain. As i was hoping to use it as a music h/d to transfer to and fro from my comp's h/d
  8. jimton
    jimton
    Jun 15, 2005
    49
    any help on this peeps? :lease:
  9. whiteairzuit
    whiteairzuit
    May 23, 2005
    14
    I know for sure that you can NOT transfere from HD5 to comp in Sonic Stage, have tried and failed. However, I will now explore the possabilty of treating it as a removable disk drive.
  10. whiteairzuit
    whiteairzuit
    May 23, 2005
    14
    After a brief snuffle about, have found that music files are displayable in explorer but in some weird order with name, which makes everything dandy. Not sure wether the online database (gracenote i think) which holds the track info which is used when a cd is put in and imported would recognise the file and retrieve the track name etc about it. Worth a try some time.
  11. Mike_manchester
    Mike_manchester
    Just a thought...
    1) plug in the device
    2) using Windows explorer, drag n drop the files from your device to a new folder on your pc
    3) tell SS to "import" the files from that new folder into your library.
    Would that work or would SS say that they are protected files etc ???
