Sonica Theater going back, need an alternative
Discussion in 'Desktop & Laptop Computers Forum' started by RadEd, Apr 17, 2003.
  1. RadEd
    RadEd
    After much frustration I'm sending the Sonica Theater 7.1 USB soundcard back, I tried everything I could think of but it refuses to output a digital signal to my amp.
    So now I need a replacement, what cards can do DTS and preferably coaxial digital out?
    thanks.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    High Wycombe, Bucks, UK
    +59
    Does it need to be USB?
    Otherwise the obvious alternative would be the Revolution 7.1 PCI version.
    For USB there are a couple of options, like the Creative Extigy or a small box made by Abit. Don't know where to find an Abit box from, i'll look around.
  3. nathan_silly
    nathan_silly
  4. RadEd
    RadEd
    I'd rather have PCI now but I'm wary about going for another M-Audio product.
    As far as I know the Creative cards don't support DTS, I'll check into it though.
  5. ReTrO
    ReTrO
    Jul 12, 2000
    3,498
    2
    71
    +59
  6. RadEd
    RadEd
    I think I'll try the Xitel Pro HiFi-Link from http://www.discountdiscs.co.uk/ (thanks for the link Nathan!) :)
    It's a nice package with all those 30ft cables :D
    Thanks a lot for the info guys! :smashin:
  7. nathan_silly
    nathan_silly
    Remove the image, Spectre might ban you..
  8. Branxx
    Branxx
    Nov 1, 2000
    801
    London, UK
    An obvious choice if you also want high-end audio quality is to use RME DIGI96/8. It can be had for approx £160. Other alternative is STAudio DSP24 Value+ for £130.
    Improtant thing with both cards is their driver technology that avoid Windows kmixer that has significant impact on sound quality. Also, both support ASIO mode.
    they are both good but RME is significat audiophile quality product.
