Sonic Stage Version 3
Discussion in 'Headphones, Earphones & Portable Music' started by Roger Matthews, Mar 8, 2005.
  1. Roger Matthews
    Roger Matthews
    Nov 11, 2004
    291
    Aberystwyth
    +15
    I hated Sonic Stage Version 2.3. Following the link published elsewhere in this forum I downloaded Sonic Stage Version 3 and it is so much better! I am now convinced that the NW-HD3 was the right choice! Try it, you won't regret it! :thumbsup:
  2. cheesephantom
    cheesephantom
    Feb 24, 2005
    14
    4
    birmingham
    could this be the answer to my omgjbox.exe problems?
  3. Roger Matthews
    Roger Matthews
    Nov 11, 2004
    291
    Aberystwyth
    +15
    "could this be the answer to my omgjbox.exe problems?"
    I wouldn't know but SS3 works fine for me. It sounds like my setup is similar to yours since I had an extensive collection of music (in .WMA form rather than MP3) collected from my own CDs via Microsoft Media Player 10. Both old & new music works well in SS3.
  4. washout
    washout
    yep sonic stage 3 is miles better, why use the european version anyway as songs are cheaper on the usa store just make sure that u have backed up your library using sonicstages own backup/restore tool, and ensure the hd is authorised with sony connect and registered on your account with them. go to music source connect music store- then account and create a new account and register. otherwise all manners of problems await.
  5. bek
    bek
    did you have to re-transfer all of your music when you upgraded SS? I've read that you have to initialise the HD3, which sounds a bit weird.
  6. esree_babe
    esree_babe
    Feb 4, 2005
    11
    Winchester
    Where can I download ss3??
    Charlotte x
    :lease:
  7. malheuresement
    malheuresement
    I had to, which was a little bit of hassle to be honest, but once I'd set the transfer going I had no problems and just came back after half an hour and all was fine.
  8. malheuresement
    malheuresement
    Try here
  9. hughesy
    hughesy
    Jan 22, 2005
    848
    Irish in Oz
    +13
    my pc at home is not connected to the web, i do most of my downloading at college/work and bring the stuff home (on my hd3).
    This installer needs to be connected to the web to work. Does anyone know how to download the files and then extract them later, or anyone know where to get the full download?? I want SS3 :lease:
  10. washout
    washout
    i dont think there is a way unfortunately
  11. hughesy
    hughesy
    Jan 22, 2005
    848
    Irish in Oz
    +13
    no worries, thanks anyway, i'll wait til it's released in Europe :smashin:
  12. watchinthewheel
    watchinthewheel
    hey thanks for the link, i just downloaded it, havent had chance to really use it yet but it looks like it could be a bit better than 2.3 at least
  13. TommoK
    TommoK
    Mar 9, 2005
    75
    Have they put a normaliser on the new version - so you can make the volume the same on all your tracks?
    I've resolved the quietness issue using the tip on this site but it would be nice to have all tracks at same volume esp when using random play.
  14. Blown383
    Blown383
    Man.... Im still having problems with SS3. It always crashes and closes itself after scanning for files. What gives?
    -B
  15. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    One problem I've found is on Compilations I have the artist set to the actual artist and not various - however sonicstage 3 therefore makes all my compilation albums into 15-20 1 track albums rather than one compilation...?!
    That needs fixing or am I doing something wrong?
    This is via import from MP3 files.
  16. diverse
    diverse
    Jan 21, 2004
    159
    16
    I had this with 1 album, i am not sure if it was ticked as compilation? you can view the album in view by album and change to compilation in properties after right clicking!
    I noticed that the title and artist were a$$ about face so i deleted it and re-imported (2 min job)!
  17. nasanu
    nasanu
    Did you guys uninstall sonicstage before installing the new version?
    I am worried about losing my collection. I remember that when I upgraded from 2.1 to 2.3 sonicstage told me that my hd1 could not be used with this version and I had to format it to get it to work. I want 3 but I am scared that if I install it I will have to format my hd1 again.
  18. sacd
    sacd
    Feb 19, 2004
    297
    Cardiff
    I'm having probles with SS3. When I import my music files into the library on some occasions SS3 puts various tracks into 1 song albums. I then have to move the song back into the proper album but it invarioubly ends up in the wrong place.
  19. watchinthewheel
    watchinthewheel
    yep you do. it uninstalls the old one automaticaly when it installs 3.0 but it also wipes your info so you have to reinitialise your hd1/3 tbh if i were you id stick to 2.3 its not that much worse than 3.0 and the time saved reseting your hd1 will be very usefull.
  20. nasanu
    nasanu
    Well I am putting my HD1 in for a free upgrade this week so I'll do it after thats done since all data will be wiped anyway.
    But the files on my harddisk will remain right? It won't wipe them?
  21. PlasmaIan
    PlasmaIan
    Apr 13, 2002
    111
    Surrey
    I thought the upgrade for HD1 was £15 ? Where is it free ?
  22. daw182
    daw182
    we get it free in australia, due to the fact we are so backwards and don't have the hd3 here.
  23. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    LOL! Thats funny.
  24. nasanu
    nasanu
    I think that makes us forward ;) I don't much like the HD3. Sure if I had never seen the HD1 I'd love it, but the looks of the HD1 and the usb cradle vs the less attractive and slightly bigger HD3 with no cradle... No contest for me. But thats another thread ;)
  25. Hasselhoffia
    Hasselhoffia
    The amusing thing is the NW-HD3 is featured on the Sony New Zealand site. Heh heh! Think that about says it all really... :)
    Incidently, version 3 is a heck of a lot more stable. 2.3 used to hang (or certainly appeared to hang) every few albums for me when trying to convert from WMA files and transfer to my HD3. Version 3.0 has so far done 1200 files overnight and is still going, and whats more, it has a progress display thats actually displaying its progress rather then not being refreshed like its predecessor. Rock on!
    I will say though that when I rip a CD and eject it, it doesn't clear the track listing. and when you stick in the next CD for ripping, it doesn't update the track listing for the new cd. The only way I could 'clear it' was to exit SonicStage and restart it, which is really stupid. Had the same with v2.3. Is everyone getting this problem?
  26. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    The hd1 is slightly smaller and doesnt have annoying rubbery ends, but the hd 3 has a white, blue, or pink backlight (depending on what colour you choose!), instead of boring old green! I also prefere the jogdial on the hd3. But thats just a matter of opinion. And, having owned both, the hd3 is really only marginly bigger than the hd1.
  27. watchinthewheel
    watchinthewheel
    what jogdial on the hd3? and what rubber ends :confused: thes no rubber on mine at all, and i cant see anything that coukd be called a jogdial really.
    personaly i think the hd3 is a very very stylish piece of kit far nicer than the ipod for instance. i havent tried a hd1 to compare though.
  28. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    The jogdial is (i think) the name of the main control bit in the centre, the bit with up-down-left-right-play-stop. On closer inspection it isnt actually rubber, but i was refering to the plastic bits at the top and bottom where the buttons (top) and hold switch etc. (bottom) are. On the hd1 this were metal, which was much sleeker.
  29. watchinthewheel
    watchinthewheel
    ahh right i thought that was what you meant, its not a jogdial though, a jog-dial is a dial not a button cluster, its hard to explain but look up the sony remote rm-mc40elk that has a jog dial you can see really clearly. i agree with you about the plastic stuff though, making it out of metal like the rest of the player would ahve given a far better impression imo.
  30. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,368
    41
    Tunbridge Wells
    +12
    Oh right. I expect I just saw the words "nw-hd3" and "jog-dial" in the same sentence or sumthing!
