Sonic Stage Upgrade
Discussion in 'Headphones, Earphones & Portable Music' started by aitchjv, Aug 9, 2005.
  1. aitchjv
    aitchjv
    I'd like to upgrade my version that came with the player to the newer one BUT i have dialup and struggle on 32kbps (if i am lucky) - normally i download at work and take home but all i can find is the installer that links to their website that downloads the whole thing - i can't keep my connection ofr that long!
    Does anyone knoe how i can get this on cd or download from another site?
    Many thanks!
    Helen
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    36,436
    +6,222
    Do you have a mate with broadband?
    The thing is you download a 700kb installer - which then downloads the 20mb+ of SonicStage and its components. I dunno if putting all of it on a CD works. Prob will?
    And the latest ver is 3.2 - but Sony UK hasn't fixed the link - you're given a 3.1 installer instead
  3. Maidenpriest
    Maidenpriest
    Jul 18, 2005
    235
    +8
    I also have a slow connection, it managed to download took about 4 hours, when the connection went off i reconnected and it carried on from where it downloaded about 12%, i had to do this several times but got there in the end???
