Sonic Stage Ripping CDs
Discussion in 'Headphones, Earphones & Portable Music' started by Bacon_N_Cheese, Aug 22, 2005.
  1. Bacon_N_Cheese
    Bacon_N_Cheese
    I have already ripped all my cds but I realized I had them in atrac3 with 128 bit. I want to change it to MP3 with the max bit rate. Is it possible without deleting all my cds and ripping them again?
  2. johann1979
    johann1979
    Feb 18, 2005
    857
    19
    London
    You would have to re-rip everything I am afraid :( If you encoded your cd's at 128kbps and then converted them to a different format at a higher bit rate you would end up with files that would have no audible difference. If anything, they would sound worse - but most like the same, definitely not any better.
  3. Bacon_N_Cheese
    Bacon_N_Cheese
    Ok but I would have to delete my old album right?
  4. Beethovenian
    Beethovenian
    No, you could keep the Atrac files if you have space and envision using them sometime (for the gapless playback, for instance, or for a flash player with less capacity). But if you plan to use only MP3, then it may not make sense keep two copies of each CD.
  5. Bacon_N_Cheese
    Bacon_N_Cheese
    Ok, so I think I am going to delete all my albums and re rip them at the highest bit rate and oin mp3 format. One last question, what sounds better, Atrac3+ or Mp3?
