Sonic Stage HD3 alphabetising
Discussion in 'Headphones, Earphones & Portable Music' started by greedoe, Jun 20, 2005.
  1. greedoe
    greedoe
    Jun 16, 2005
    48
    11
    Wallington
    +3
    When I import files onto my HD3 in Sonic Stage they seem to appear on the HD3 pane in the order they were imported. Can I re-order these alphabetically to get a better idea of what I have on there?
    Too many times I've imported the same album twice as I missed seeing it in my cursory glance of what I actually have on the player.
  2. JB5
    JB5
    Apr 18, 2005
    231
    +16
    I believe the only way to do this is to manually drag the albums into the correct order.
    If you disconnect the HD3 then the lists will be alphabetized on the device, but will still be in the transfer order when shown in the transfer window in SS.
    However, if you want to know which albums need to be transferred then if you click on auto when the HD3 is connected on the transfer window on SS, a list will appear of albums not already transferred onto you device. Each album can be individually deselected if desired.
