Sonic stage alternative
Discussion in 'Headphones, Earphones & Portable Music' started by JWALKR, Mar 29, 2006.
  1. JWALKR
    JWALKR
    Oct 13, 2005
    33
    11
    hey guys, as i said earlier my ss wud not scan for new mp3 files. then i tried to uninstall it/ now it wont install! this is soooo fuhked! fuhk sony corp man.
    is there any other program to load mp3s on to hd5?
  2. realslimcookie
    realslimcookie
    Oct 6, 2004
    243
    Hull, UK
    +3
    do a global search in AVForums for the following text
    "Sonicstage Replacemnt HERE!"
    Regards,
    Realslimcookie.
  3. JWALKR
    JWALKR
    Oct 13, 2005
    33
    11
  4. realslimcookie
    realslimcookie
    Oct 6, 2004
    243
    Hull, UK
    +3
    Sorry mate, it did use to work but it must have been closed down or try again at a later time. Have a good look around this forum.
    Regards,
    Realslimcookie.
  5. picmalkin
    picmalkin
    Oct 16, 2005
    540
    Staffordshire
    +17
    I have used the vaio music transfer program (a drag and drop facility) with my previous vaio and hd-3.
    You should be able to find this on the vaio music player support site (via the vaio site).
    Encoding mp3s (into sony's protected oma format) does take a little time so down loading your whole library can take a few hours.
  6. KeithO
    KeithO
    May 28, 2003
    1,435
    63
    Erding, Bavaria
    +214
