Sonic Stage album/track naming
Discussion in 'Headphones, Earphones & Portable Music' started by MASDAC, Aug 4, 2005.
  1. MASDAC
    MASDAC
    Anyone else experience problems naming albums/tracks etc. using sonicstage 3.1 .When i load the cd into pc for transfering onto my hdd. Gracenote asks me to register, click yes and it informs me ' cannot retrieve cd info , happens everytime. Any ideas, thanks
  2. JB5
    JB5
    Apr 18, 2005
    231
    +16
  3. shadowritten
    shadowritten
    I was thinking the same, but wasn't as brave as you to suggest it!
  4. MASDAC
    MASDAC
    yes sorry. i should have stated that i am online when transfering
  5. MASDAC
    MASDAC
    thanks for the thread JB5 will try those suggestions. regards
  6. JB5
    JB5
    Apr 18, 2005
    231
    +16
    The standing joke at work when something doesn't function is to ask - "Is it plugged in? Is it switched on?"
    Surprising how often it actually solves the problem! ;)
    NB. The above is in no way a dig at MASDAC, like I said eliminate the obvious first. Good luck with the tips in the thread BTW.
