sonic stage album order
Discussion in 'Headphones, Earphones & Portable Music' started by watchinthewheel, Apr 23, 2005.
  1. watchinthewheel
    watchinthewheel
    does anyone know if there is a way to make ss3.0 display the music on the hd3 in a reasonble order, ie alphabetical by artist? when i first put my music on it did this automaticaly but when i add anything new it goes straigt to the bottom of the list. i can maualy drag it up the list but it takes AGES to get to the top its so annoying when you like bands that start with A. is there any way to do this automaticaly that you guys know of?
    a solution to this or any advice would be great, thanks.
  2. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,221
    +6,428
    If u have mouse with scroll wheel, what I do is left click and hold down, on album once, so its selected. Then still holding left mouse button on selected album, with other hand use scroll wheel 2 go 2 top of list quickly.
    other than this, I don't think theres a lot u can do
    U listening Sony? Firmware update...
  3. djarend
    djarend
    yeah, this is something which i haTE TO, i also want it in alphabetical order, and i hope there is a way to do it automatically, drag and drop is too musch work for me
  4. scottydog
    scottydog
    Mar 22, 2005
    55
    It DOES put things in automatic alphabetical artist order for me on the HD3 in 'Artist' view. Its in alpha order by album name in 'Album' view. Group view however is all over the place and I've abandoned using it except for playlists. In 'Groups' view (and on SonicStage) it does show things in the order I transfer things on to it unless you drag them into order on SS. As I said I find Groups totally useless for my needs so I'm dragging playlists into alpha order but thats all. I'm sure I could use groups better but its way too time consuming.
