Sonic Stage 2.0 help.
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Dougster, Aug 10, 2004.
  1. Dougster
    Dougster
    Any ideas on how I back up to mini disc a 'dance' mix which I have saved as individual files.
    They play fine in WMP but once transfered there is a noticable skip in-between each track instead of them mixing in smoothly?
    TIA
  2. booktrunk
    booktrunk
    Feb 6, 2004
    623
    Leicestershire
    +3
    It sounds like your CD-R or RW is setup to put a 2 second skip in between tracks. You might be able to configure this out in the software. Failing that try dowloading a demo copy of some other software.
    Steff
  3. Dougster
    Dougster
    I'm recording each file direct to MDLP mini disc at the LP2 setting?
    There is no 2 second pause, just an annoying click that affects the smooth transition of the mix.
    How do I configure Sonic Stage to stream all tracks as one?
