Sonic Link/Black Rhodium speaker cable
Discussion in 'Home Cinema Speakers' started by Markmw, May 9, 2003.
  1. Markmw
    Markmw
    Does anyone have any experience with these loudspeaker cables?
    Just bought some Monitor Audio Silver S1s from Sevenoaks and want to make the most out of my £50 free cabling. Since I'm not bi-wiring I can perhaps afford to upgrade a little above the standard QED SA wire.
    Was offered some of the Sonic Link/Black Rhodium S300 for £15/m, and was told that plugs didn't need to be air-free with this cable due to the silver, ie screw on is fine.
    Sounded a bit dubious to me since it's only silver plated, although Sevenokas did say they could solder some plugs on for me.
    The Black Rhodium website wasn't particularly insightful, and Hi-Fi Choice wasn't particularly impressed with the S300.
    Has anyone any knowledge or thoughts on this cable, and whether the plugs should be air-free? The branch of Sevenoaks didn't seem to have any other cable in between this and the QED SA.
    Mark
  2. shoalin kid
    shoalin kid
    i use the sonic link ast 200 in my hi fi set up well worth the money deep bass but exspresive.have nt heard this 1 but give it a go
