Songs downloaded from iTunes on the HD5
Discussion in 'iPhone Forum' started by pop_disaster86, Aug 7, 2005.
Tags:
  1. pop_disaster86
    pop_disaster86
    Is it possible to transfer songs that I have legally downloaded from iTunes onto a non-Apple mp3 player? (Specifically, the Sony HD5)
    I've got an mp3 converting program to convert WMAs and WAVs into mp3s etc, but it doesn't seem to be able to recognise iTunes songs to convert them. I assume they are protected by Apple or something like that?
  2. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,236
    +63
    Your best option is to burn the tracks to CD and then import them into Sonicstage. All of the major online music sellers use copy protected files.
  3. pjskel
    pjskel
    Oct 12, 2004
    2,676
    83
    UK
    +124
    Your iTMS songs are AAC encoded, so nothing short of iTunes and an iPod are going to have the decoders to play them back.
    Converting from one lossy codec to another via AIFF (CD Audio), is not going to make the songs sound all that good.
    I presume you have/had an iPod prior to buying songs off iTMS? If not, then you really should've read things before buying blindly. Sorry, that's the way it is.
  4. shadowritten
    shadowritten
    Yep, I'd go with this advice. And don't worry about generation loss or lost sonic info transcoding from one lossy codec (AAC) to another (MP3, ATRAC, or whatever). I've done this many times, sometimes to ridiculous levels, and everything sounds just fine to me. :smashin:
    Repeat the mantra: lossy isn't hi-fi, lossy isn't hi-fi ...
  5. Ryanmixu
    Ryanmixu
    Mar 15, 2005
    132
    +9
    do a google search asaking the same question mate might give you a few ideas :smashin:
