Sona Glass Hi-Fi Stand from Argos
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by jtfab75, Jul 17, 2005.
  1. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    Sona Glass Hi-Fi Stand cat no. 534435
    would the above stand fit my amp and dvd recorder ?
    anyone got one ?
    thanks
  2. JayDub
    JayDub
    Jun 6, 2005
    63
    +8
    A colleague of mine has bought one and is very happy with it.
    Apparently it fits standard size hifi components with no problems.
    It doesn't have spiked feet, but that means you can slide it across carpet much more easily.
    Looks like a very cost effective bit of kit to me.
  3. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    thanks,bought it first thing and just put it up.looks fab !
    thanks again for the help
  4. Metman
    Metman
    Jun 30, 2005
    45
    Cullompton
    Can you just use part of it as a 2 shelf unit? I want just a 2 shelf unit to sit on top of a solid cabinet (cabinet has DVDs stored in) to house DVD player, amp and PVR - the only other one I can find to fit the bill is the Apollo, which at £200 is a bit pricey.
  5. jtfab75
    jtfab75
    Jul 13, 2004
    810
    BRADFORD
    +10
    yeh i guess you could but you will have to cut the 4 threaded bars to the correct size.
  6. getdownmonkeyma
    getdownmonkeyma
    Aug 25, 2004
    196
    +7
    Have one myself, great unit, very sturdy.
    I would like a TV stand to match (not the one in Argos), has anybody come across other TV units by Sona?.
  7. JayDub
    JayDub
    Jun 6, 2005
    63
    +8
  8. briancowings@ho
    briancowings@ho
    Feb 27, 2005
    47
    +3
