Somethings corrupt....
jamez2010
To put simply, I have spent a night trying to fix my pc...nearly threw it. It appears some embedded cache that no matter what I do I can sort, I have used malware bytes, cccleaner etc the fault is images mainly but anything Internet based appears corrupt, mainly within google chrome, but switch it into incognito mode all is fine, hence my thinking its cache based, also noticed it appeared in my iTunes Store :( any one shed any light? For info it's win 7 pro )4bit and a self build pc
Stiggy
Have you tried completely uninstalling Chrome and then reinstalling?
Does it do it with other browsers?
simplicity96
Or just delete the app data folder which should reset the browser. It will simply be remade next time you start the app.
