Quantcast
Question Something to lift centre speaker upward so fires more towards ear level?
nugget2014
My centre speaker is quite far down. On my tv unit shelf. And supposedly having it fire towards your ear is what you should be doing. So is there any kind of object of I can put under the speaker to angle it upwards a bit ?
jimster99
Or you can use a couple (or more) door wedges. That's what I've done and it looks surprisingly good and works well!
Harkon321
As above two rubber door wedges.
