Something to bother fixing?
Discussion in 'Plasma TVs Forum' started by Krance, Feb 8, 2005.
  1. Krance
    Krance
    I have an issue (not really a problem I think)
    I have a Denon 3910 DVD player which should be great, I have a nice component cable going to a Panny PWD7. I think the picture looks pretty good and have had a play with the settings etc.
    Question is, when I have nothing playing on the DVD player but it is turned on I seems to get a whole screen of very slight interference (small green dots). Should I be getting this? and should I worry about it?
    I have checked cables for obvious interference, tried playing around with ferrite core and all that, nothing seems to remove this. When playing DVD material I can't see any interference but I also couldn't tell you that it is the best picture (nothing to compare against).
    What do you think? should I worry and trace the cause...
  2. cboy
    cboy
    Dec 29, 2004
    559
    +4
    i thought the ferrite core was just to connect the lap top or pc to the panel?
  3. Krance
    Krance
    that is true, they stop interference in certain circumstances. It was just something I tried, didn't work anyway :(
  4. lack300
    lack300
    Feb 25, 2005
    1,467
    Bedford
    +46
    I also had this problem but nocking the brightness back 1 got rid of dots.
