Flimber
Display: PWD8
Scaler : VP20
If I'm set for 50Hz output on the scaler, when I switch to a 60Hz input the screen goes blank. And vice versa. I have to manually go and change the output to 'convert' the thing to interpolate everything back into 50Hz and that brings in horrid, juddery motion effects. The screen can accept 720P/1080i at either 50 or 60 Hz without a problem but the scaler doesn't seem to want to pass the framerate on untouched, only converted. And this is a master setting. I can't find a way to preset an output so I can just have a remote sort it out with a Macro. If I switch from a VM box (50Hz, even for the Youtube app, the idiots) to a PC (60Hz), or an R2 DVD to an R1 DVD, the screen goes blank. Does that make sense ? Could it be the panel at fault ?
The DVDO Edge and Duo both do Hz in = Hz out (regardless of resolution, the framerate is passed through with ignorance).
Mike.
Scaler : VP20
Mike.
