Something simple for the kitchen (music streaming)
Discussion in 'Music Streamers' started by GGGav, Aug 15, 2013.
  1. GGGav
    GGGav
    Nov 30, 2009
    12
    Folks,
    Is there something simple and inexpensive I can put in the kitchen which will provide:
    - FM
    - DAB
    - Streaming of MP3 library from Media Centre PC (wireless-ly)
    - an iPod to dock (for charging and playback)
    I can see things like the Roberts ColourStream which I think would meet all the requirements but it is £250.
    Are there less expensive devices out there?
    Gavin
  2. amcluesent
    amcluesent
    Aug 13, 2002
    5,240
    Glasgow
    +1,167
  3. GGGav
    GGGav
    Nov 30, 2009
    12
    Thanks for that. I've had a look at the threads and come up with these
    Pure Evoke Flow £125
    Way too Retro
    Roberts Stream 63i £300
    Roberts ColourStream £188
    Revo Axis XS £180
    I think I should declare at this point that there is another requirement: we (me and the wife) can stand retro. So I'm afraid the Pure Evoke Flow and its' ilke are out.
    The Roberts Stream 63i is too expensive.
    The Roberts ColourStream and the Revo Axis XS might do, they seem to tick all the boxes, but I was hoping to do this for less - or am I just kidding myself here?
    GGGav
  4. ufitsy
    ufitsy
    Aug 18, 2004
    3,273
    103
    Midlands
    +346
    secondhand squeezebox boom? (no ipod dock)
  5. Cebolla
    Cebolla
    Jan 27, 2013
    1,649
    +266
    How about the Pioneer X-SMC3. You can get them for ~£140 now & Tesco doing refurbished units with 12 month warranty on eBay for £90!
    Has your spec except no DAB, but internet radio instead (arguably much better for choice & sound quality) and you also get AirPlay for wireless streaming from iTunes. Only problem might be size, it's ~52cm wide & ~22cm high (dock's at bottom front of unit, so won't affect height).
    If you must spend that £250, then if it were me I'd consider a micro & seperate speaker system. Occupies about the same space as the X-SMC3, if you keep speakers at side of unit - you just need to consider how often you'll actually be moving it and not so ideal for the smaller kitchens. Something like the Pioneer X-HM71 at £259 (per your spec, but again no DAB, though has internet radio, Airplay support plus cd player & free control app for Android & iOS devices).
  6. GGGav
    GGGav
    Nov 30, 2009
    12
    Thanks for the input everyone - it's given me plenty to think about.
