Something similar to a Mission 77c1
Discussion in 'Home Cinema Speakers' started by john_p, Nov 16, 2003.
  1. john_p
    john_p
    May 15, 2003
    70
    I want to get a centre speaker for my Mission 773e pair. However I am having difficulty tracking down a 77c1, as these are now a couple of generations old and nobody has any stock any more. Looking in classifieds and on ebay but I don't hold out much hope ..
    I was thinking about buying one of the newer Mission speakers - say the m7c - will it still be a reasonable match? Or will it sound odd?
  2. Dimmy
    Dimmy
    Jan 15, 2003
    2,399
    39
    England
    It will sound odd, and the worst place to have mis-matched voicing between speakers is across a front soundstage. Were I you, I'd keep waiting for the 77C1 you're after to pop up - they always do eventually (fortunately I got hold of one).
  3. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,665
    Bristol.
    +309
    I understand, all of the Mission 'M' range have the same tonal qualities and timbre so you could actually use the M7c1 or the M7c2 which are both very, very good speakers.
    However, of the two, the M7c2 is supposed to be the subjectively better speaker - although in my opinion, it does not look as nice :rolleyes:
    Here is a good UK supplier -
    www.hifibitz.co.uk
    By the way, I asked Mission the above info at a recent trade show and they say that these will match.
    Hope this helps.
    Cap:)
  4. john_p
    john_p
    May 15, 2003
    70
    I asked them too, at the What Hi Fi show near Olympia, although embarassingly I completely forgot what they told me :blush:
    I will have a listen to that speaker and see how it sounds.
  5. Sunil
    Sunil
    Apr 27, 2003
    93
    London
    If I were you I'd actually go for the M5C rather than M7C1 or M7C2. Saying that, if you can find a 77C1, that is the best match, as I found comparing the two with my 773e's and 77DS's.
    In fact, I now use both the M5C and 77C1 in a (frowned-upon) double-centre configuration, which in my opinon adds power and focus to voices compared to the 77C1 on its own.
  6. john_p
    john_p
    May 15, 2003
    70
    Why's that Sunil? What differences did you notice?
  7. Sunil
    Sunil
    Apr 27, 2003
    93
    London
    The centre channel just has a bit more welly, so voices do not get drowned out by music coming out of other speakers. With just one centre speaker I used to increase the volume of the centre channel by a few dB's to make it more prominent. Now I don't need to.
  8. rozzar
    rozzar
    Sep 29, 2002
    1,055
    41
    Braintree
    +23
    i had a Mission 77c1- awful , dire centre speaker
    my Celestion Centre 2 sounded better
    the Mission m78c is a nice sounding centre speaker though and the material of the drive units is closer to the 77 series than the m7cx range
    remember that 50% of the movie goes to the centre speaker, so its arguably the most important speaker. get a good 'un, don't settle for 2nd best.
  9. bobbypunk
    bobbypunk
    the latest good match is a v6c which (if you have room for it) is pretty good.
