someone with a Rel Q***e sub please help
Discussion in 'Subwoofers' started by Frustin, Aug 8, 2001.
  1. Frustin
    Frustin
    do i need to plug my amp lead into both of the RCA sockets?
    I have: High level twin Neutrik Speakon and low level twin phonos 0db +12dB respectively, on the sub itself. Am i only to use one cable with one single RCA plug on each end or am i going to need a bi-wire with two plugs on each end. OR WHAT?
    Please bare in mind i dont have my amp ( <a href="http://www.homecinemachoice.com/testbench/Amplifiers/Denon/DenonAVC-A10SE.shtml" target="_blank">Denon AVC-A10SE</a> ) yet (tuesday next week).
  2. Guest
    You only need to use one lead, normally into the 0db socket.
  3. AVMAN
    AVMAN
    You can just use one of the RCA connections as its a mono signal,but if you can get a decent splitter then do it because like the B&W ASW 2500 sub if you use a splitter you get a extra 2db which dont sound a lot but it is with sub levels,this is also the case for the KEF KHT sub as well.
