someone tried Sony KV32FD1 with an Iscan Pro in SVGA socket?
Discussion in 'General TV Discussions Forum' started by karyboue, Feb 22, 2002.
  1. karyboue
    karyboue
    Jan 30, 2002
    200
    France
    +18
    I believe it may work, but...
  2. DaveH
    DaveH
    Aug 1, 2000
    740
    28
    Surbiton, Surrey
    +34
    This interests me too.
    I was also wondering whether it was possible to get component video through this socket?
    If anyone could shed any light on this and the IScan then that would be most helpful.
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    I suspect that the FD1 will ot accept componet YUV through it's VGA socket, more than likely only RGBS and RGBHV.
    The Iscan Pro should work on it, though expect only upto 848x480p, which would discount PAL pro-scan.
  4. karyboue
    karyboue
    Jan 30, 2002
    200
    France
    +18
    I don't think there is any cable component<>vga.
    I contacted silicon image but had no answer yet.
    As the svga socket seems to be an rgbhv (from the service manual schemes) it should work fine with the iscan pro.
    The problem is to know if the set can accept directly a 768*576 resolution without passing by the 800*600 (svga) mode. If it is not the case we will have a 4/3 letter box image, which means a little smaller than a 28" with black borders all around because the full mode in vga-svga only enlarges the width.
    1-is it possible to activate the 16/9 ratio via the menu service in PC-in input?
    2-is it possible to make the tv accept directly a 768*576 resolution?
  5. karyboue
    karyboue
    Jan 30, 2002
    200
    France
    +18
    it might be possible to plug
    DVD in component socket
    VCR in composite socket
    SUB tuner (2nd tuner) un sVideo socket
    ...of the iscan
    does it seem crazy?
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,217
    +3,072
  7. karyboue
    karyboue
    Jan 30, 2002
    200
    France
    +18
    If it accepts 640*480 and 800*600 why wouldn't it accept direct 768*576? There's something I don't get there. Might be an electronical incompatibility or ...?
    The refresh frequencies are from 50 to 75hz in 480 and 600 acording to my computer videocard. In the menu of the set another frequency appears, I don't know what it is, it's variable. All I remember is 800*600 at 75hz/48khz
    The other thing is that the set accepts higher resolutions even if lines are missing, so it should be possible to play blindly with the missing lines to center and resize the image?
    It goes up to 1280 (limit of my videocard) but half of the screen is missing.
    would it be dangerous for the tube or the electronic?
  8. karyboue
    karyboue
    Jan 30, 2002
    200
    France
    +18
    Here are the resolutions
    640*480
    Computer TV/vga socket
    60hz 59hz/31,4khz
    67 66/35
    75 75/37,5
    800*600
    56 56/35,1
    60 60/37,8
    72 72/48
    75 75/46,8
    Hope someone can help.
  9. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    If it will handle 800x600p properly, then it should do 720x576p.
    There's only one way to find out.
  10. Gordon @ Convergent AV
    Jul 13, 2000
    14,217
    +3,072
    Usually devices like these save convergence settings dependant on scan rate and resolution. 800x600 @ 60Hz is no where near the same as 720 X [email protected] that's the problem. If the thing hasn;t been set up with geometry and convergence for this res it wont work.....Other thing is that it's extremely unlikely it'll be able to resolve 800 x 600 anyway. Sure it may accept such a signal but you ar every likely to be overlapping scan lines causing a serious softening of the image....
    Gordon
  11. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    Gordon: I guess spending £1k on a Quadscan HD would be overkill?
  12. karyboue
    karyboue
    Jan 30, 2002
    200
    France
    +18
    I now understand why my computeur only displays a very small image in the middle of the screen, it only de-interlaces (as an iscan would).
    If I understand well, the signal needs to be de-interlaced and rescaled as a quadscan (?) should do. But, what a price.
    Thanks to all, for the infos.
    Brice
