someone please reassure me about heat and vents!
Discussion in 'AV Receivers & Amplifiers' started by chedmaster, Jun 5, 2005.
  1. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    I have an azur 540r, and have had in the past sherwood amps which i had stuff on top of, and they broke (both the same fault) and i wonder if it was heat build up causing this.
    Im now terrified of putting things on top of my amp, where there is loads of vents and although i don't feel much heat rising (there is some but not boiling), its very hot to touch.
    So the question is, will putting things on top of the amp, or not leaving much room for ventilation in general (there'll be lots round side and back) damage the amp and/or shorten the life of the amp. I realise there is safety circuits but i'd rather not test them out!
    Someone told me the Azur amp had a fan, i see no fan or hear no fan, can anyone confirm this?
  2. Deejah
    Deejah
    May 19, 2005
    114
    19
    Surrey
    the azur as i guess u know does get very hot, so i guess it would be best if u didnt put something on top, it deffinetly needs to be well ventilated.
  3. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    i feared this... any other views?
    ps deejah you shouldnt of sold it!
  4. Deejah
    Deejah
    May 19, 2005
    114
    19
    Surrey
    :D me thinks im going to get this a lot from you :rotfl:
  5. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    No idea how hot the 540R gets (my Marantz with it's meaty current feedback tech gets pretty warm) but you could try creating a shelf above it to give it some more breathing space. I used to have a few halved squash balls with a board of wood on top of that rested on my old Denon 1802 so I could put my DVD player above it. :)
  6. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
  7. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    if you look at my stand, with a drill i could move the middle shelf down, how much room do you think is needed? were the half squash balls enough? thanks
  8. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    ps i just realised i subconsiously copied your signature wording, will change it!
  9. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    The squash balls were enough but the 1802 didn't get very warm. My 7400 in it's cabinet has about 6cm above it and more to the side which seems to be plenty. A couple of inches should be OK for most people but it would be best to check the manual for this information.
    What are you actually trying to achieve here? :)
  10. chedmaster
    chedmaster
    Jan 29, 2005
    2,661
    68
    +28
    i wanted to keep silver things together (away from my black arcam), the dvd player is smaller than the reciever so it looks pants underneath, and i wanted to put the dvd player on top, but it seems more trouble than its worth. Answer - Azur dvd player.
