Someone help me out :(
M
mridley
Can someone please explain this, what is the best setting to use on a Denon 2802, do you have the "AFDM" set to on or off?
Do you set to "MTRX ON" or "NON MTRX", If someone can find the time to explain this i would be most grateful, I just can't get my head around the manual.
Thanks in advance
LDR
This setting is used for 6.1 or above speaker systems. Non Matrix is used for full DTS-ES (discrete) discs & Matrix is used for non discrete discs. Set AFDM to OFF.
Jase
MATRIX ON means the information for the Surround Backs is extracted from the normal Left & Right Surrounds, you also leave it in this mode for DTS ES Discrete discs as the amp will automatically switch into the Discrete format. You´ll know what mode the amp is in as it will be displayed on the front panel.
MATRIX OFF means that the sound of the Left & Right Surrounds is redirected to the Surround Back speakers without undergoing any matrix processing.
Leave the AFDM (Auto Flag Detect Mode) switched OFF and just manually switch the Surround Backs on/off depending on the disc.
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
