somebody help please-what cables do i need to get started and how much?
Discussion in 'Cables & Switches' started by RonBurgundy, Sep 8, 2005.
  1. RonBurgundy
    RonBurgundy
    Jun 13, 2005
    1,439
    41
    +21
    hi guys...newbie needs help
    need to connect up an lg plasma, harman kardon avr amp, and dvd player and also either freeview or sky digital..........what do i need and whats the best way to do it? oh by the way.... on a pretty tight budget so 2nd hand from forums not a problem if i know what im after!
    id say plasma will be max 1.5m higher than the amp when wall mounted!
    thanks
