Some upgrade advice please gentlemen
Discussion in 'AV Receivers & Amplifiers' started by Majik, Dec 19, 2004.
  1. Majik
    Majik
    Jun 10, 2003
    193
    Coventry
    Having been reasonablyhappy with my setup for some time now, I feel I may be missing out on something due to the "weak link" in my system.
    As a poor git, I consider my suff pretty good for what I can afford. I have a simple question for you all. The weak link is obviously my amp/processor - if I upgrade will I see a big difference in quality and enjoyment in my home cinema? Volume isn't important at all as I live in a flat so can only go so far. If y'all think it is worth upgrading, fancy throwing some sub 500 ideas at me?
    eBench Lidl special DVD player
    Boston Micro 90 Centre
    Boston Micro 90 Fronts
    Polk Audio FX700i rears
    PSW2000 sub
    PSW1000 sub
    Daewoo 32 inch widescreen Flat
    Thanks guys,
    Majik
  2. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    Have you thought about the Yamaha DSP-AX750SE? Probably one of the best amps for under £500 put there!
  3. Majik
    Majik
    Jun 10, 2003
    193
    Coventry
    No sir, but I have now and disapear to the search function...
    Can anyone answer my first question - will I see a marked improvement in replacing the amp?
    Thanks bud,
    Majik
  4. rags
    rags
    Apr 13, 2003
    4,161
    London
    +324
    I may have missed it but what amp are you currently using ?
  5. Majik
    Majik
    Jun 10, 2003
    193
    Coventry
    What an absolute idiot I am. Gibbering like a fool without saying what amp.
    Sorry.
    Sherwood R6108R
    DPL2, DTS, DD, RDS radio etc
    Majik
  6. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    I think you would see an improvement, why don't you try and demo one!
  7. The13thGryphon
    The13thGryphon
    Majik,
    I think that you should also consider the Harman Kardon AVR325. I know that HK's wattage specifications look low to many folks, but they punch way above their weight, and they put out high current into low impedance loads. They "sound" much more powerful than their ratings would indicate, and I'd put 50 Harman Kardon watts up against any other receiver brands 100 watts. Their gear just simply sounds fantastic. :D
  8. The Gooner
    The Gooner
    Dec 5, 2004
    1,390
    48
    NE Lincs
    +44
    I have just purchased a Denon 2805 from Peter Tyson for £520.
    Just over the 500 mark but it is a good amp, I have certainly noticed a diff betwen my old budget Sony amp and this. Theres just 2 many settings to fiddle with :suicide: gets me confused as I dont understand half of them
  9. Tejstar
    Tejstar
    Dec 4, 2002
    22,808
    London
    +1,081
    The Denon 2805 is a fantastic amp if oyu can afford it!
