Some Sound Advice
Discussion in 'AV Receivers & Amplifiers' started by ISAMA, May 2, 2003.
  1. ISAMA
    ISAMA
    I have just connected a Tosh Home Cinema sd42 up to a Philips 9527 despite the wife going on all the time in my ear!!
    The question I have is reading the TV manual I could use the TV for my centre sound or I presume the speaker supplied.If so which is best and how would I use my TV to set it up.
    Also whilst watching Sky is the best set up Pro-Logic.
    Hope someone can help.
  2. Andywilliams
    Andywilliams
    Sep 27, 2002
    2,080
    notts.
    +63
    Hi Isama
    Use the speaker supplied with the tosh as its important that the front three speakers have the same tone this will sound better than the tvs speaker.Listen to tv broadcasts and sky in prologic 11 hope this helps.
    Gonzo. :)
