Some Sky channels reception gone
Discussion in 'Sky Digital TV Forum' started by neilneil, Dec 10, 2004.
  1. neilneil
    neilneil
    Jan 2, 2002
    720
    28
    +39
    My movie channels have all gone so blockey that I get no picture at all except Movies 7 and 9 which are perfect. BBC news 24 has also gone, so has a number of other channels. Some of the low budget channels are ok though.
    Does this indicate a specific problem ie LNB can't reach those high notes any more! or does it perhaps show poor dish alignment or bad cable.
    I don't think It's poor alignment because I've spent hours minutley adjusting it to a really good signal on many channels it's just the few broken ones that have gone completley.
    What do you think?
    -Neil
  2. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    Bradford, West Yorkshire.
    +323
    Neil,
    Pretty sure you've got a faulty LNB there. Probably the 'Cambridge' one at a guess. Easy DIY job to replace. You should be able to pick one up for under £20.
    A.Dork
  3. neilneil
    neilneil
    Jan 2, 2002
    720
    28
    +39
    Thanks AD, I've replaced the LNB and all the channels have returned. :thumbsup:
    You even managed to predict correctly the make of my broken cambridge LNB :D
    -Neil
  4. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,365
    +323
    You're very welcome Neil. :)
    A. Dork
