Some questions about my TV setup
T
Tony Williams
Right guys CURRENTLY I have these;
LG RZ-32LZ55, TV
Sky Digibox connected via SCART
PSTwo connected via composite-to-SCART
The TV has the following inputs
side panel; -
SVideo
Component (RBG - PR PB Y)
Audio L & R
back; -
RS232C
DVI Input
PC Sound - 3.5 mm jack
2x SCART
ANT in (analgoe ariel)
(no HDMI :thumbsdow)
Also note this TV is HD (720p)
Right first question is, I am using the standed composite-to-SCART that I got with the PSTwo and the quilty isn't too great, small text isn't easy to read and it's a little blurry would it be wise to use component insted (since that can carry HD? - I know the PSTwo isn't HD but will I see better?)
Second I am planning on soon getting an Xbox 360 and this'll use component-HD my TV just has the one set of component and I don't think it'll be fun switching and swapping them all around all the time. As for the DVI/3.5mm they'll be used up on a HTPC when I get it back.
I know it's not much at the moment but it'll kinda look like this diagram:
I don't really know what a receiver does or how it would work, all I know is it hooks everything up to speakers, or something like that? Could I use one and hook my htpc, sky box, pstwo, xbox 360 to the tv and a pair of speakers, well maybe a 5.1 set?
Can someone do a diagram of how it would all wire up? :lease: and I think I could have speakers too (cheap ones - student, no job)
Thanks,
Tony Williams
:arty:
GreenBars
If you want to add an extra component input to allow you to connect both consoles at the same time you could try one of these - a JS Technology component switcher. I used to have the scart equivalent and it was excellent piece of kit - great customer support too. Not cheap, but probably cheaper than buying a receiver
