Some potentially silly questions!
Discussion in 'Projectors, Screens & Video Processors' started by jtorry, Dec 28, 2002.
  1. jtorry
    jtorry
    Nov 8, 2001
    522
    Right. Here are a few questions I have about projectors that may be obvious to some, but I just want to clarify things.
    1. All my CRT TV's have suffered from image persistence/light smears. This happens when a light moves across the screen or when a lit face moves into darkness. Would a LCD projector have this problem (Sanyo PLV-Z1 in particular)?
    2. When a film is true widescreen and has black borders, are these black borders part of the projected image?
    3. All the screens I have seen have a black frame. As i am making my screen, would a wooden frame painted with Balckboard paint do the job?
    4. What is the optimal height for a screen to be at in relation to head height?
    Feel free to laugh at me stupidity, but any help will be great. Thanks.
  2. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    Cant answer cos not sure what you mean.
    Yes. Because the pannel is 16:9 so the DVD has black borders encoded in it to fill the screan, which the projector the displays.
    Yes. Blackboard paint will do the job, the reason for the black boarder is to absorb any extra light from keystone correction etc.
    Thats subjective and depends on the user. Experiment with the PJ on a white wall untill you find a postion that is comfortable for you, then mount you screan accordingly
  3. jtorry
    jtorry
    Nov 8, 2001
    522
    What i am trying to say is that on my CRT's i moving lights leave trails behind them. Eg. A street light will leave a line of light behind it as the camera pans across the screen.
  4. JonMace
    JonMace
    Nov 20, 2002
    2,567
    83
    Kent
    +210
    Have not seen that on my PJ but then can't recall seeing it on a CRT so maybe its something I'm not sensitive to.
  5. Smurfin
    Smurfin
    Aug 13, 2002
    21,421
    +4,349
    jtorry I know what you mean, and no, you won't find that to be a problem on the Z1 (or any projector as far as I know).
  6. Insp.Gadget
    Insp.Gadget
    Dec 4, 2002
    135
    South East
    +3
    While we're on the subject of some potentially silly questions :clown: , can someone answer a question I have - where would you position the HS10 in order to have no keystone correction whatsoever (either horizontal or vertical) - lens exactly in the centre of the projected image, or is the throw on projectors angled so that they are best for ceiling mounting ?
    Apologies for the noob question !!
    Jtorry, in answer to your 4th question, I have read in a few places that ideally your eye-line should be a third of the way up the screen, but I expect personal pref is what counts at the end of the day.
  7. Harb
    Harb
    The Smearing you are refering to is caused by Phosfor Persistance or Lag.
    As LCD projectors don't use Phosfor,....you don't have the problem.
    John
  8. jtorry
    jtorry
    Nov 8, 2001
    522
    Thanks. That is what i wanted to hear.
  9. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    Insp.Gadget:
    I think it will be like most other PJ's in that near the bottom or top if inverted are the best positons. Has for keystone just make sure your PJ is dead square to the screen, this is harder than you think and can take quite a bit of fiddling making very small adjustments to the position of your PJ.
