some newbie questions
BoroFanUK
just bought an iphone.
1. whats the best *free* software to convert movies / tv shows to the iphone format?
2. is it possible to dock the iphone to charge without itunes starting up?
3. can you rearrange the icons/apps on the startup screen?
4. can you change to your own mp3 etc ringtone and txt tone?
cheers :smashin:
WWFCB
Don't know about the first two, but, for re-aranging your icons just hold your finger on one of the icons for a short while & they will then start to wobble (the icons will not your fingers), you can then move them around. Once finished just press your 'home' button.
For ringtones, try the link below.
Link removed
Hope this helps.
:thumbsup:
WWFCB
Don't know mate, I wouldn't mind altering mine if you could alter them.
cheers :smashin:
1 - Videora (works great for me.)
2 - Yes there is an option on i-tunes i believe to turn off auto start i-tunes when connected.
3 - As above
4 - As above for ringtones, you can only change your message tone when it is jailbroken (i believe)
:smashin:
BoroFanUK
cheers guys.
maybe one slight problem. my pc just restarted with 'computer will shutdown in one minute' message. i hope its not the iphone / itunes software as its normally rock solid. running vista home premium 64bit.
