Some help would really be apprecited!
Discussion in 'General TV Discussions Forum' started by elviobarros, Mar 11, 2002.
  1. elviobarros
    elviobarros
    I am currently fishing around for a new widescreen tv. I do like the look of the sony 28fq75 (a 32 fq75 would be too big for my living room). After finally deciding to go for one i went to my local A/V store to purchase one, only to be told it was now discontinued!!!!!!! AAAAARRRRRGGGGHHHHHH, that was annoying.
    Does anyone know if sony are planning on releasing a replacement for the 28 fq75 (with a better looking remote!!!). Its just that i need a bigger tv as i am now Fed up of watching a portable. Should i wait for the new sony range or is there any other tv's out ther with the same picture quality as the fq75??
  2. M.Joshi
    M.Joshi
    Oct 10, 2000
    249
    Harrow.
    +9
    As far as I am aware, this t.v is still current. If you do not need 100Hz / DRC, you could go for the LS35 range or KV-28FX65.
