Some help with graphics
Discussion in 'PC Gaming & Rigs' started by monkeyleader, Apr 24, 2003.
  1. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    A few months ago I got meself a GeForce4 Ti 4800 card - problem was it kept crashing when playing games or even in 3DMark. Was convinced it was something to do with the PSU not supporting the additional grunt. Due to a growing impatience and lack of time I decided to leave my machine into the comp.shop in Cambridge .... they fixed it and as far as I can remember they installed AGP 8x support - since then Ive installed XP on my system, but its back to crashing again when playing games - any ideas if this 8X support is a BIOS thing (ive also upgraded the BIOS to fix a problem with NVIDIA cards and XP) or a windows driver thing - any ideas much appreciated - Im desperatly missing BattleField 1942 ;)
    ta,
    monkey
  2. nathan_silly
    nathan_silly
    (Intel?) chipset...
    Install Intel INF chipset drivers
    Install Intel Acceleration driver
    Go into BIOS and select AGP X8, or maybe select AGP X4 (maybe X8 is causing problems?)
  3. Sinzer
    Sinzer
    May 25, 2002
    5,823
    +1,117
    Have you upgraded the Nvidia drivers?
  4. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    yes latest drivers are installed, as was the case with Win2K - it was something to do with AGP 8x - I have a KT7a motherboard
  5. CMcK
    CMcK
    Mar 18, 2003
    408
    Scotland
    +29
    Check all of the following:
    You have the latest WHQL certified nVidia drivers?
    You are using Direct X 8.1 or later?
    You have the latest Hyperion drivers for your motherboard?
    Go into the BIOS and check that AGP 8x and Fast Writes are enabled.
    Let me know how you get on.
  6. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    thanks for this - Im actually away this weekend so wont get a chance to look at it until Sunday - will let you know
    thanks again
    monkey
  7. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    Okay so back trying to get this working .. I have checked in the BIOS and both fast write and 4x is enabled (does not give me an option for 8x) I am also using DX 9.0, and have downloaded the latest drivers from the NVIDIA website ..
    still crashes when i try and play a game
    ideas ?
  8. monkeyleader
    monkeyleader
    Jan 13, 2002
    2,621
    71
    Cambridge, UK
    +87
    Thanks for the pointers - looks like a school boy error - did not have Via 4-in-1 for my motherboard ... all working now..
    monkey
