Some help with a dell 5150c please.
Discussion in 'Desktop & Laptop Computers Forum' started by theninjagecko, Apr 28, 2007.
  1. theninjagecko
    theninjagecko
    Feb 2, 2005
    613
    Walsall
    +27
    I have a dell 5150c wich has onboard graphics and a x600se pci express graphics card. but i can only use one at once else the machine wont start up and tells me to use the pcix card.
    is there anyway of using both outputs on the 5150?
  2. lowmans100
    lowmans100
    Dec 20, 2006
    1,487
    +465
    No, I'm afraid not. If you want dual monitors you will have to upgrade your gfx card.
  3. theninjagecko
    theninjagecko
    Feb 2, 2005
    613
    Walsall
    +27
    Cant get one to fit in it tho :(
  4. Naqv
    Naqv
    Oct 15, 2006
    3,646
    Birmingham
    +355
    As said above, you'll have to buy a newer card that supports dual output. Just get any cheap newer card and it should support dual output.
  5. theninjagecko
    theninjagecko
    Feb 2, 2005
    613
    Walsall
    +27
    they wont physically fit into the dell 5150c, its really low profile, thats why im struggling here.
  6. Uridium
    Uridium
    Jan 29, 2005
    14,434
    North West Leicestershire
    +1,855
  7. theninjagecko
    theninjagecko
    Feb 2, 2005
    613
    Walsall
    +27
  8. lowmans100
    lowmans100
    Dec 20, 2006
    1,487
    +465
    I don't understand when you say you can't get an upgraded gfx card to fit. I have a 5150C and have fitted a Geforce 7600GT (XFX 7600GT XXX) http://www.scan.co.uk/Products/ProductInfo.asp?WebProductID=458375 it takes up a single slot and supports two monitors.
    There are other single slot dual monitor gfx cards on the market.
