Some help to get me started
Discussion in 'AV Receivers & Amplifiers' started by loofer, Dec 8, 2004.
  1. loofer
    loofer
    Feb 2, 2001
    185
    +4
    I currently have a 28 inch digital Sony widescreen with an X-box as a dvd player and i'm looking to add a surround sound set up, my budget is about 300 pounds, i'm not looking for tons of power just a nice clean surround sound effect for movies and games, could someone answer a few questions?
    1) What are the pro's and cons of an integrated dvd player and amp over a dedicated amp?
    2) if i wanted to add a dvd recorder to my set up would it still be easy enough to have the games console connected as well?
    3) If i play an audio CD do i need the TV on or does it work independantly?
    4) Would you have any manufacturer or, even better, a model to recommend?
    Any help would be greatly appreciated, thanks.
  2. Paulholio
    Paulholio
    OK here goes
    1)You only have 300 pound to spend so you have a choice of.......not a lot. I think you have to go for a DAV system
    2)Depends what connection you have on your TV
    3)No TV needed
    4)Have a look at these DENONS
