Some help please with picture quality on a RPTV
Discussion in 'General TV Discussions Forum' started by dealstokie, Jun 3, 2005.
  1. dealstokie
    dealstokie
    May 16, 2005
    383
    Hi there,
    I have a Toshiba RPTV, just bought it second hand, could I please have some help with the picture settings.
    Im also a newbie to RPTV
    I dont think there is much of a problem with convergance ( I think )
    Here is a list of what is connect to the tv and how :
    Old Pace Ondigital box ( using for top up tv ) connected via Gold Jvc ribbon scart cable.
    CheapAccustic solutions DVD player connected via Gold Jvc ribbon scart cable.
    PS2 via standard 3rca + scart block
    Gamecube via 3rca
    ____First of all, would I be better of using better scart leads ( lower end of ixos ? )____
    Now for the picture quality.
    Nothing ( i think ) is RGB
    ( 1 ) Everything seems to suffer slightly when very bright colours are used ( ie, menues, white colours, sky spot news ect ) The white colours seem tosuffer the worst, It seems to 'bleed' past the area's its suppose to be ( ie menu's the letters are white, but the white appears the 'smudge the letters ? )
    (2) Sharness does not seem to be to good when looking at background pictures , but is great close range.
    (3) I cant seem to get the contrast/brightness right its either to dark or to light.
    (4) I dont seem to get as good a picture from the Digibox compared to the rest of the items connected, Is this because of the digibox being old?
    I think thats about right, these problems are not to bad really, but just seeing If I can improve them.
    I hope it all makes sense to you all.
    :lease: :lease: :lease: :lease: :lease: :lease: :lease: :lease: :lease:
  2. Tight Git
    Tight Git
    Mar 3, 2004
    6,332
    +597
    Maybe someone with this particular model can be more specific, but from your description, that sounds not too bad for an RPTV.
    Don't try to compare it with a CRT TV or you'll be disappointed. :lesson:
    See what RP's look like in a local dealers, but remember yours is secondhand with (probably) worn tubes.
    Good luck. :)
  3. dealstokie
    dealstokie
    May 16, 2005
    383
    Nice One M8.
