Some help needed to complete system
Discussion in 'Home Cinema Speakers' started by Diving Bear, Jan 16, 2005.
  1. Diving Bear
    Diving Bear
    I need to tap into the expertise, knowledge etc of this forum.
    I have been putting together my system bit by bit and am now stuck on the speakers.
    I have a Philips 32PF9986 screen, a Sony RDRGX300 DVD Recorder and am getting a Yamaha DSP AX750se amp. So far so good. Now what speakers should I add?
    I don't have a very large room; space is a premium.
    The screen is going to be wall mounted with some space immediatly under fora centre speaker as long as it is small.
    Front speakers can be larger, either floor or bookshelf.
    I am mostly interested in the video sound, not likley to use it much for music, although this needs to be ok.
    Mrs Bear has insisted on a light wood finish (which stops the Mission M30, my first choice). She doesn't want silver finish either.
    Budget £500-700
    So over to you..... what would work??? :lease:
  2. Crazer
    Crazer
    Dec 4, 2004
    29
    Pontypridd
    have you looked at the Mission M3i Cinema. 5 stars in what hifi. Might stuggle with your budget mind.
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    see the CANTON CD1 thread.......................
  4. Diving Bear
    Diving Bear
    Just reading it now.... very interesting. Could get the amp from Germany as well???
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    yep BALLISTIX has done just that and is expecting it soon..............
  6. Tejstar
    Tejstar
    Dec 4, 2002
    22,797
    London
    +1,080
    A lot of people have ordered without problems. I think Stinky recently ordered a Yamaha 1500 from TechnikDirect.
  7. Diving Bear
    Diving Bear
    Is. it worth it? The price difference for the AX750 is only £60 and I'm not convinced by the Canton CD1s. I am keener on the Mordaunt Short Premiere Plus with the 309 sub. Or maybe MAs.
  8. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,331
    +261
    For 250 notes mate,the canton's are fantastic value for money,sound is superb.
    believe me I know how demanding the other half can be as well!
  9. Strobe
    Strobe
    Aug 29, 2003
    2,868
    Southampton
    +146
    What about the MS Genies in black? £799 so a tad over-budget but def worth it.
