Some help choosing new Kit
Discussion in 'Plasma TVs Forum' started by Dunwa, Oct 13, 2004.
  1. Dunwa
    Dunwa
    Oct 13, 2004
    1,185
    63
    Sydney
    +129
    Hi there,
    Another n00b here looking for some help. I'm looking take the dive and dump my old CRT telly and invest in a plasma. Reading through the boards it looks like the most popular choice is the PW6 or PW7, what I need help with is all the other bits and bods that will be required to connect all my kit.
    So basically here's what I have.
    DVD player
    VCR Player
    Xbox
    5.1 Amp
    I'll need to get a freeview box (any recomendations ?) to be able to "watch" anything, I'm not interested in Sky or Cable.
    Any help will be greatly appreciated.
    :lease:
  2. Leigh_1973
    Leigh_1973
    Jan 28, 2004
    721
    UK
    +16
    you should also add and JS technology RGB to VGA convertor.
    Freeview ----> RGB in on JS T box -----> VGA out to VGA in on plasma.
    you'll get a far better picture this way than using the scart board
  3. happyh
    happyh
    Aug 6, 2004
    309
    Northants Riviera
    Get a Pany viera.
    All your kit will connect, it has freeview and analogue tuner.the panel is the same as pw6.
    The picture quality is great and it looks the business.
    I am biased as I have one.
