Some hand holding needed...noob alert!
Discussion in 'Networking & NAS' started by wiz, Mar 1, 2014.
  1. wiz
    wiz
    Aug 20, 2000
    4,476
    +4,215
    Recently bought a Netgear ReadyNas Duo RND2110 V1) for music streaming duties to a new Sonos system.
    This has no drives so stuck a spare 500GB drive a had spare.
    Gone though the wizard but can not put music on it. I thought all I had to do was drag and drop. Is this not the case?
    That status says it is offline don't know why.
    Thanks in advance
    Ossie
  2. bubblegum57
    bubblegum57
    Jan 5, 2010
    1,922
    +310
    I don't know for sure, but I thought with nas's you had to setup the filesystem on the hard drive first, so it will probably put ext4 ? on it.
    Then you can copy either over the network, or plug in a usb to copy to the nas drive.
  3. cjed
    cjed
    Oct 30, 2007
    2,272
    116
    Highworth, Wiltshire
    +587
    It's a long time since I used a Netgear NAS, but I have a feeling that by default it will try and create an XRAID volume - which requires 2 disks. This would account for the volume remaining offline - it needs a second disk. It would help if you could post a screenshot showing the NAS status screen - it should say what kind of volume it's created.
  4. wiz
    wiz
    Aug 20, 2000
    4,476
    +4,215
    This is what I have!
    It did cross my mind about having two disks but I've just seen on the box that you can insert an optional disk. So it would seem I should be able to run it with one disk.
    The only thing I can think of is it needs a 1000 GB hard disk to start with as that what it had from new
  5. whitestar96
    whitestar96
    Dec 5, 2006
    582
    28
    +63
    Did you buy this from new or is this second hand? The reason I ask is that you mention it originally had a 1TB disk in it. If it's second hand you may need to reset it to factory defaults, if I remember correctly there is a small pin hole in the back which you depress while booting the system. If you don't have the manual have a look on the Netgear website.
  6. wiz
    wiz
    Aug 20, 2000
    4,476
    +4,215
    Bought it from the classifieds. Will try the reset
  7. wiz
    wiz
    Aug 20, 2000
    4,476
    +4,215
    The reset did it, Thanks guys!!
